Thank you for visiting the AUSTRALIA HP Store
It looks like you're in United States, would you prefer to shop in that country or continue exploring the AUSTRALIA HP Store?
Exc. public holidays
In 2025, the office for Australians is increasingly wherever remote employees are based: a busy café in Melbourne, a Qantas airline seat, or a beachside villa in Queensland. The significant rise in remote work across Australia, paired with the relentless pace of business travel between our sprawling major cities, and the appeal of the digital nomad lifestyle, have led to a skyrocketing demand for adaptable workspaces. Central to this new way of remote working is the humble portable monitor. What was once a niche accessory—a lightweight, secondary screen—has become an essential tool for the modern Australian professional.
Consider this article your field guide to navigating portable monitors for your remote work endeavours. We’ll break down the technologies behind these displays, explain their potential to optimise your remote workflow, and help you choose the best portable monitor for your unique setup.
Charging this evolution is USB-C connectivity. This single-cable solution handles both power and video signal to eliminate the need for cumbersome power adapters and multiple cables. Beyond USB-C, touchscreen capabilities have become increasingly common as they offer intuitive interaction for tasks like drawing, note-taking, and complex software navigation. Additionally, foldable designs allow displays to be easily tucked into a bag or cases for even better portability.
Finding the best portable monitor starts with understanding what specs to watch out for:
Resolution: Measured in pixels, resolution determines the sharpness and clarity of the image. Higher resolutions, such as 1920x1080 (Full HD) or 2560x1440 (QHD), provide more detail and are ideal for tasks like photo and video editing.
Panel Type: Most notable are IPS or OLED, panel type affects colour accuracy, viewing angles, and contrast. IPS panels are known for their excellent colour reproduction and wide viewing angles, making them suitable for most users. OLED panels, while typically more expensive, offer superior contrast and vibrant colours, appealing to creative professionals.
Brightness: Measured in nits, brightness determines how well the monitor performs in different lighting conditions. A higher brightness rating is essential for working outdoors or in heavily lit environments.
TIP: For outdoor use, look for monitors with at least 300 nits of brightness. For predominantly indoor use, 250 nits should be sufficient for most environments.
It’s tempting to compare portable monitors directly to traditional external monitors, but they serve different purposes. While traditional monitors prioritise screen size and advanced features, portable monitors emphasise portability, ease of use, and quick setup, and are designed to extend the functionality of your primary device rather than replace it entirely.
Convenience is just the start because portable screens deliver a measurable productivity surge. Dual-screen setups consistently demonstrate faster task completion, improved multitasking, and better organisation. For remote workers, frequent flyers between Sydney and Perth, and location-independent professionals, portable monitor setups mean a more accelerated work process.
Here’s how portable monitors optimise productivity across different roles:
Remote Workers: Create dual-screen setups in home offices, coffee shops, and co-working spaces, boosting productivity wherever they are.
Business Travellers: Turn hotel rooms and airport boarding lounges into efficient workspaces to stay connected and productive on the road.
Field Workers: Deliver clear and engaging presentations to clients in any setting to boost client engagement.
Creatives: Dual displays allow for the simultaneous display of tool palettes and timelines that transform laptops into capable design studios for photo and video editing, and digital art.
Coders: Portable monitors facilitate efficient debugging. Code can be displayed on one screen, and debugging tools on the other.
Students: Research and write more efficiently with resources and materials on one screen and composition on the other, optimising organisation and focus.
Portable monitors allow you to position your screen at eye level to reduce neck strain and improve overall comfort, which is particularly beneficial for those who frequently work in cramped spaces or on uneven surfaces. By minimising the need to hunch over a laptop screen, you can mitigate the risk of musculoskeletal issues.
Portable monitors are also excellent for space efficiency and flexibility within remote work and travel setups. Unlike traditional external monitors, they require minimal desk space and can be easily packed away when not in use. This makes them ideal for small apartments, co-working spaces, or temporary workstations.
Battery life considerations and power management are foundations of a truly portable work setup. While many portable monitors draw power from the connected device via USB-C, others feature built-in batteries for extended use.
It’s important to evaluate the power consumption of your portable monitor and laptop. If using USB-C power delivery, make sure your laptop’s power adapter can supply sufficient wattage to power both your laptop and the monitor. For battery-powered models, consider the rated battery life and how it aligns with your typical usage patterns. If you frequently work in locations without reliable power outlets, a battery-powered option or a high-capacity power bank might be necessary.
TIP: When selecting a USB-C powered monitor, check if it supports power pass-through capabilities, allowing you to charge your laptop through the monitor while using a single power adapter.
Plenty of portable monitor types are available, catering to every workflow.
Powered by USB, these portable monitors are the most common type. They offer a balance of portability, affordability, and performance, making them suitable for general productivity tasks. These monitors typically feature IPS panels and Full HD resolution, providing crisp visuals and wide viewing angles.
These models offer an interactive experience that lets users navigate applications, annotate documents, and draw directly on the screen. This is particularly beneficial for creative professionals, students, and anyone who prefers a more intuitive interface. Touchscreen monitors often support stylus input, further enhancing their versatility.
For those who require true portability without relying on a laptop’s power, these monitors feature built-in batteries that provide several hours of use and allow you to work independently of a power source. They are ideal for outdoor use, travel, or situations where access to power is limited.
These models cater to niche user groups:
High Colour Accuracy Monitors: Often featuring OLED or high-end IPS panels, these are perfect for creative professionals who need precise colour reproduction. These monitors are essential for tasks like photo editing, video editing, and graphic design.
High Refresh Rate Monitors: With refresh rates of 144Hz or higher, these are geared towards gamers who want a smooth and responsive gaming experience on the go.
Form factor innovation is driving the portable monitor market head-on into the future. Foldable displays maximise portability through compact design while rollable monitors and ones with integrated peripheral solutions like stands and keyboards are pushing the boundaries of mobile computing to offer tailored configurations for diverse users.
The addition of a portable monitor to your existing workflow should not cause disruption. You can ensure this with reliable connectivity and broad compatibility.
The gold standard, offering a single-cable solution for both power and video signal. USB-C, with its versatile capabilities, supports DisplayPort Alternate Mode and enables the transmission of high-resolution video and audio. Thunderbolt, while less common in portable monitors, offers even higher bandwidth, making it ideal for demanding applications like video editing.
These ports provide alternative connectivity solutions. HDMI is widely compatible with various devices, including laptops, gaming consoles, and media players, while DisplayPort, often found on higher-end laptops and desktops, supports higher refresh rates and resolutions. However, these options often require separate power cables, which can add to clutter.
Most portable monitors are designed to work seamlessly with laptops but compatibility with tablets and smartphones is steadily rising. Many Android devices support DisplayPort Alternate Mode via USB-C, which allows them to connect directly to a portable monitor. Note that compatibility with iOS devices may be limited and often require adapters or specific models.
If your portable monitor draws power from your laptop via USB-C, your laptop’s USB-C port needs Power Delivery (PD) support to ensure the monitor receives sufficient power without excessively draining your laptop’s battery. Some monitors require an external power source, especially those with higher brightness or advanced features.
Wireless options offer a cable-free experience for users. They still come with limitations such as latency, which may not be ideal for tasks requiring precise timing, such as gaming or video editing. Wireless options may also rely on Wi-Fi or proprietary wireless protocols, which can impact compatibility and performance.
Here’s how to maximise your output while you’re on the move:
Physical Setup: Adjustable stands and mounts are highly recommended for ergonomic comfort. Optimising height and viewing angles can help reduce strain. Integrated foldable cases offer convenient stand options.
Software Configuration: Familiarise yourself with your operating system’s display settings. Configure your preferred dual-screen layout and resolution for optimal workflow.
Cable Organisation: Effective cable management is essential for a tidy workspace. Use cable organisers to minimise clutter and improve efficiency.
Travel Considerations: For frequent travel, durable carrying cases are a necessity. Consider compact travel stands and mounts for easy setup in various locations.
Productivity Apps for Dual Screen Efficiency: Productivity applications can further optimise your dual-screen workflow. Consider apps that facilitate window management, virtual desktop creation, or task automation. Apps like Magnet, Spectacle, and DisplayFusion provide robust window management features, while the likes of Todoist and Notion can help you stay focused and organised.
TIP: Windows users can take advantage of the built-in “Snap Assist” feature (Windows key + arrow keys) to quickly organise windows across dual displays. Mac users can utilise Mission Control (F3 key) for similar functionality.
The HP E14 G4 Portable Monitor is engineered for professionals who need flexibility and performance on the go. Ideal for frequent travellers between Australian cities, this slim and lightweight monitor boasts a 14-inch Full HD IPS LCD display that delivers crisp visuals and wide viewing angles. With an ultra-bright, anti-glare, 400-nit screen, the HP E14 G4 gives a clear view regardless of your environment. Whether you’re in a dimly lit room or working under Australia’s bright sunlight, the visuals remain sharp.
14-inch screen size with FHD (1920 x 1080) resolution
IPS display type for excellent colour reproduction
5ms GtG response time with overdrive
2 SuperSpeed USB Type-C® 5Gbps signaling rate (Alt mode DisplayPort™ 1.2)
On-screen controls, low blue light mode, and anti-glare features
Weighing just 640 grams and measuring less than 4.75mm thick, the HP E14 G4 slides seamlessly into carrying cases and offers dual-screen productivity without adding bulk. Its energy-efficient design also lets you work without interruptions. Requiring half the power of its predecessor, the HP E14 G4 features an integrated 65W power pass-through that allows you to power the monitor from your laptop’s USB-C port while simultaneously charging your laptop from its power brick.
With its balance of portability, display quality, power efficiency, and even environmental consciousness, this portable monitor is a top choice for Australian professionals who need a reliable second screen to add to their work setup. It’s particularly valuable for those working across Australia’s varied environments, from city offices to remote outback locations.
Before purchasing a portable monitor, here’s a quick checklist of factors to consider:
Screen Size and Resolution: Crucial for visual clarity and productivity.
Connectivity: Such as USB-C, HDMI, and DisplayPort, should align with your devices.
Portability: Consider the monitor’s weight and thickness.
Panel Type and Brightness: Affect image quality and visibility in different lighting conditions.
Price-to-Feature Ratio Analysis: Compare the features and specifications of different models within your budget to determine which offers the best value.
Warranty and Support: For peace of mind, check the warranty period and ensure that the manufacturer offers reliable customer support in Australia.
Accessories: Enhance your portable monitor experience with accessories like a carrying case or sleeve for protection, a portable stand for improved ergonomics, and a high-quality USB-C cable for reliable connectivity.
Future-Proofing Your Investment: Choose a monitor with features and connectivity options that will remain relevant in the coming years. USB-C connectivity and high-resolution displays are likely to become increasingly common.
TIP: Consider your primary use case when selecting a portable monitor. If you’ll be using it mainly for text-based work, a Full HD resolution is sufficient. For creative work involving detailed graphics, consider higher resolutions like QHD or 4K.
When using portable monitors, especially during extended periods, it’s important to consider their impact on your health and wellbeing. Proper ergonomics can prevent strain and promote better posture, while features like blue light reduction can help protect your eyes during long work sessions.
Setting up your portable monitor at eye level and at an appropriate distance can significantly reduce neck and eye strain. Consider investing in a portable monitor stand or adjustable case to achieve the optimal viewing angle. Additionally, take regular breaks following the 20-20-20 rule: every 20 minutes, look at something 20 feet away for 20 seconds.
Many portable monitors now include blue light reduction features to help mitigate the potential negative effects of prolonged screen exposure. This is particularly valuable for Australians who might find themselves working unusual hours to accommodate international time zones.
As technology continues to evolve, the portable monitor segment is poised for more exciting advancements. Expect smarter foldable displays that adapt to your needs, seamless wireless connectivity that frees you from clutter, and even more intuitive touchscreen capabilities for unparalleled user interaction. These innovations are already on the horizon, hinting at a future of more versatile mobile displays.
For Australians dealing with unique challenges like intense sunlight and vast distances between major centres, future portable displays might feature even higher brightness levels, longer battery life, and more robust build quality to withstand the demanding conditions of the Australian environment.
Looking ahead, we can anticipate portable monitors that incorporate artificial intelligence to automatically adjust settings based on your environment and usage patterns, maximising both productivity and comfort across Australia’s diverse working environments.
Ready for a more powerful workstation? Check out HP’s range of monitors and laptop accessories for your next essential upgrade to complement your portable monitor setup.
