If you were to ask your parents or grandparents what they expected 2025 to be like, many would have said we’d have flying cars by now. While mankind hasn’t quite achieved that level of development, we did get the next best thing.
The invention of electric vehicles has easily been one of the biggest advancements of this century thus far. However, not many people know that these vehicles can do so much more than simply transport you from point A to point B. In the UK, where power cuts can occur during severe weather events or grid maintenance, your EV might be the perfect backup solution.
Powering your Home During Power Cuts With your Electric Vehicle
Power cuts are not only a huge inconvenience but also disrupt your day-to-day life by taking basic communication or environmental appliances away from you. They can affect several communities at once, requiring swift restoration of services. Imagine waking up on a chilly winter morning in Britain and finding out you can’t make your tea because of a power cut. This is why having an alternate power source is always a good idea, especially if an emergency occurs. An available electric vehicle can provide that backup power, and that source may very well be sitting in your driveway already.
EVs or electric vehicles are an emerging source of reliable power backups thanks to the utilisation of bi-directional charging. This technology enables energy to flow from your electric vehicle to the power grid, home, or devices through bidirectional EV charging. Bidirectional chargers allow some EVs to come equipped with V2L, V2H, or V2G capabilities.
- V2L: Vehicle-to-load technology allows your vehicle to connect and supply power directly to the devices and appliances of your choice.
- V2H: Vehicle-to-home connects your vehicle directly to your home’s electrical system, distributing power throughout the connection.
- V2G: Vehicle-to-grid takes it one step further, connecting your car directly to the power grid, distributing it over a larger area. V2G offers a solution for the main power grid during peak demand.
In this guide, we’ll focus on the V2L technology as it offers reliability during emergencies. If you’re trying to get access to your communication devices or just want to turn the heating back on for a few hours during a particularly cold day in the UK, V2L charging is essential. So read on, especially if you own an electric car or are considering buying one.
Understanding Bidirectional Charging Technology
Before we jump into V2L, let’s take a quick look at what bidirectional EV charging is and how it operates. As the name suggests, this charging technology allows power to move in both directions when connected to an outlet. The bidirectional EV charger is a pivotal piece in this system. This enables your vehicle to both send and receive power, turning it into a power bank for your house. Bidirectional charging requires compatible systems.
Bidirectional charging priorities have made V2L, V2G, and V2H accessible for users. This technology is increasingly available and is provided by a number of manufacturers. Amongst these types, the V2L is the most accessible form of charging and allows the everyday user to get the most out of their investments.
Cars with V2L capabilities come equipped with a built-in inverter and a power outlet, allowing users to plug in appliances and devices, powering them directly from their car. Unfortunately, not all electric vehicles come with this functionality. However, some of the higher-end models do have it, provided by leading automakers. Automakers are increasingly offering bidirectional charging features in their EVs, including several models available in the UK market.
How Does V2L Work?
But why doesn’t every EV work as a power bank? Isn’t it just turning the flow of current in the opposite direction? Well, to do that, your vehicle will need:
- Bidirectional Inverter: This is needed to convert the DC power running in the car’s battery into usable AC electricity.
- V2L-compatible Outlets: The outlets are necessary for safely plugging devices into your car without damaging them or the car batteries.
- Battery Capacity: Enough storage space in your car’s battery to be used over extended time periods.
Benefits of Using your EV as a Home Power Source
Taking the obvious convenience out of the equation, the benefits of turning your car into a home power source are much more cost-effective and eco-friendly to keep your home up and running during emergencies. This is especially important when considering how long power cuts can sometimes last in the UK, particularly in rural areas after storms. Here’s what you need to know:
- Reliability: Often, power cuts occur because of natural disasters, such as storms or severe weather. The impact can be far-reaching. This is why having a V2L EV as a backup generator can keep all your essentials running.
- Energy Independence: With a V2L-enabled EV, the quality of your home life is enhanced significantly during outages, thanks to effective load management through stored power. This is most apparent during camping trips or stays in remote cottages where you can have energy backup wherever you go.
- Cost Saving: Having your car work as the power backup for your home can cut down the costs of running a noisy generator and can also help you save quite a bit of money over running and upkeep costs that come with a fuel-powered generator for your house.
Limitations and Considerations
But even with a V2L, there are a few limitations and considerations that you need to keep in mind when turning your car into a power bank. Let’s take a look at some of them:
- Power Capacity: Unlike dedicated generators, a V2L cannot power up your entire house and has very strict output limits. This means that although you can power essentials like your routers and lights, you cannot run demanding appliances beyond a certain load.
- Risk of Battery Depletion: One of the most common uses of a V2L is that of a backup source in case of emergencies. However, if your EV’s battery runs out during one such emergency, you’d be left with no essentials and no transportation.
- Weather Considerations: The UK’s often cold and damp weather can impact battery efficiency, so this must be factored into your planning when using an EV as backup power.
Setting Up your EV for Home Power
Now that we’ve covered all the considerations and you’ve decided to hook up some of your appliances to your V2L just to check how it works, here’s what to do in a power cut:
Before getting started with the setup, here are a few precautions to keep in mind:
- Make sure to check the wattage limit before plugging in your appliances, and make sure it’s supported.
- Keep your garage well-ventilated to keep the batteries from overheating.
- Ensure you have a surge protector installed to protect your car and appliances.
- Be mindful of British electrical standards and safety regulations when setting up your system.
Step-by-step Guide
Finally, you’re ready to hook your devices up. It is a very straightforward process as well because all you have to do is:
- Check up on your battery levels.
- Locate the V2L adapter or outlet in your car.
- Plug your devices or extension cords into the outlet.
- Monitor battery usage to make sure you keep it above certain levels to use in case of emergencies.
- Perform regular software updates to ensure compatibility with new electric appliances.
- Unplug the appliances before using your car as transportation.
And that’s all there is to it! Now, you can finally get back to your daily activities without worrying about the power cut.
Real-World Applications
No one wants to imagine being in the middle of a natural disaster. However, it’s always better to have something and not need it than to need it and not have it. During trying times around the world, EV owners have successfully used their vehicles as backup power sources.
For instance, during a series of storms that hit parts of northern England, several EV owners reported using their vehicles to power essential household items like refrigerators, lights, and charging stations for communication devices. This turned their homes into functional smart home environments despite the broader power outages.
Similarly, after flooding in parts of Wales, families with multiple EVs were able to rotate vehicle usage to maintain continuous power to critical home systems while the grid was being repaired. These examples show how much investing smartly in a multi-purpose car can help you out during unforeseen emergencies. It also offers an effective plan for energy management using your vehicle’s battery stored power.
Future of EV Power Integration with Smart Homes
Electric vehicles have just made their way to the consumer market and will only get better as technology improves. Bidirectional charging technology will significantly impact the state of energy consumption. Here are a few developments that are already in the works:
- V2H: Will allow users to power their entire homes with a singular backup in the form of your EV.
- Smart Energy Management: AI implementation with V2L technology will allow for better optimisation of energy management between your car and appliances.
- Integration with Smart Homes: Integration with smart home systems thanks to smart home apps and automated energy use based on grid demand and real-time prices.
- UK Grid Balancing: The National Grid in the UK is already exploring how EVs can help balance electricity demand during peak times, potentially offering financial incentives to EV owners who participate.
How HP Can Help in This Integration Process
Since home automation became a thing, HP has been at the forefront of bringing convenience to users by integrating smart technologies into home ecosystems, enhancing the owner’s experience and the system’s
sustainability.
In the past decade, HP has spent countless resources to bring automation to domestic users, allowing people to control everything remotely through interconnected home networks.
Energy Efficiency Initiatives
- Energy Star® Certification: HP, thanks to its commitment to efficient energy, has been recognised by the governing authority at Energy Star, setting for the certification due to meeting most of the standards.
- Sustainable Products: When designing new products, the biggest focus is on sustainability, ensuring that each product is efficient in its processing and comes with reduced environmental impacts.
Conclusion
As EVs continue to evolve beyond being merely transportation, technologies like the V2L have been the game-changer for power grid resilience and offering a reliable power source for your home during emergencies. This is particularly relevant in the UK, where weather-related power cuts and grid maintenance can sometimes disrupt daily life.
As this technology continues to evolve, companies like HP are making sure that your home tech keeps up with it. From driving innovation in smart home integrations to seamless household optimisations, their products can help support your energy goals. To learn more about how they can achieve that, visit
HP and take a look at how we can achieve a more connected, sustainable future.
About the Author
Taaha Muffasil is a contributing writer for HP® Tech Takes and also a tech enthusiast who tries to get his hands on all the latest tech developments. This has equipped him with the knowledge to create informative content regarding upcoming technologies and their application.
