Thank you for visiting the INDIA HP Store
It looks like you're in United States, would you prefer to shop in that country or continue exploring the INDIA HP Store?
Mon-Sat 9.00am - 7.00pm
Laser printers are no longer an extravagance for only large-sized enterprises. They’re now used by every business size across every conceivable industry. Not only are there many cost-effective models, but they are also offered in compact sizes with wireless capabilities.
Compact wireless laser printers fit virtually any space and budget and are especially compatible for home and home office use. They are ideal for those who need to print a lot, but these days, that includes most of us.
We'll take a look at 5 of the best compact HP® wireless colour laser printers available for you to buy right now. But first, let's consider what a wireless printer is and what you should keep in mind as you shop for one.
A wireless printer can communicate via standards-based technologies like Bluetooth or WiFi radio transmissions. WiFi, which uses radio waves to transmit information at 2.4 GHz and 5 GHz frequencies, allows you to print documents remotely.
Network printers require direct connections to your computer via wire or cable interfaces. Wireless printers, on the other hand, connect using wireless technologies rather than cables. So wireless printers free you to print from virtually anywhere.
A compact printer is one with a small, light footprint that takes up less space than larger and heavier models. They fit more easily into home offices and cubicles as well as smaller offices. Inkjet printers typically rule this category, although there are indeed compact laser printers that match the size and other benefits of inkjets.
Inkjet and laser printers differ in several ways. Laser printers often print much faster with more precise lines than inkjet printers, and they’re outfitted with high-capacity paper trays.
While they’re usually larger than inkjet printers, these printers do come in compact sizes. The most important difference is probably the printing medium itself. Inkjet printers use ink, while laser printers use toner powder.
When choosing the best compact laser printer, there are a few features to consider.
Laser printers used to be black and white only; monochrome. Now you can find great colour laser printers as well. While monochrome laser printers only use one toner cartridge, colour laser printers need four of them; black, cyan (blue), magenta, and yellow, which will increase your initial toner costs.
Keep in mind the types of documents that you regularly print when choosing between colour and black and white. If most of your prints are long text documents or diagrams with precise black lines, then you may not need colour for your office printer.
As the name suggests, a multifunction printer (MFP) doesn’t just print, but also performs one or more other tasks, including copying, scanning, and even faxing. MFPs are also known as all-in-one (AiO) printers. How you plan to use your laser printer will help determine which of these functions you require.
Printer output varies widely across printers and depends on many factors, including ink vs toner, and colour vs black only. Pages per minute (ppm) can average as much as 50 ppm or as few as 15 ppm. Laser printers are engineered to print faster, thus with higher ppm, than inkjet printers.
Duty cycle refers to the maximum number of pages per month of imaged output that a printer can handle without negatively impacting the health of the printer and the quality of the prints. Laser printers with their toner cartridges can print thousands of pages each month. Many also have high-capacity paper trays to print more pages without user input.
Some laser printers offer automated or automatic duplex printing, which doesn’t require you to have to manually feed the paperback in the printer. Duplex (or two-sided) printing helps reduce paper waste and, as a result, overall printing costs.
A printer’s capacity is how many sheets of paper its trays (both input and output) can hold; these ranges anywhere from 50 to 250 sheets.
One of the best small laser printers for home, the HP LaserJet Pro M15w is small enough to fit almost anywhere. It weighs only 8.4 lbs, which compares to many inkjet models, and measures 13.6 inches wide by 7.5 inches deep by 6.3 inches high.
Fast, easy printing
The smart and elegantly designed printer speeds through print jobs with print speeds of up to 19 ppm with the first page out in 8.1 seconds. This monochrome printer uses efficient, cost-effective, and pre-installed Original HP Toner cartridges, and prints up to approximately 1,000 pages with the replacement toner cartridge.
Save energy and reduce environmental impact
This HP LaserJet Pro printer is equipped with HP Auto-On/Auto-Off technology. This feature turns the printer on directly after it receives a new task, and turns it off after finishing it, helping to reduce energy waste during idle times. And to reduce environmental impact, it is also ENERGY STAR® approved with an EPEAT® Silver rating.
Print from anywhere
This small wireless colour laser printer lets you print easily from a variety of devices. Connect your smartphone or tablet directly to your printer and print without accessing a network. Wireless networking lets you seamlessly share resources as well. And with the HP Smart App, you can print from the cloud, scan from your smartphone, and easily order toner.
The HP LaserJet Pro MFP M29w is one of the best HP wireless laser printers, as well as the world's smallest laser in its class compared to the dimensions of a majority of worldwide personal monochrome laser MFPs. At just under 12 lbs, and 14.2 inches wide by 10.4 inches deep and 7.8 inches high, it’s the perfect fit for virtually any space and budget.
An all-in-one to print from anywhere
This space-saving all-in-one printer is designed to fit your life and space, allowing you to print from any spot; table, shelf, counter, or desk. It’s perfect for individuals or small work teams looking for reliable, affordable performance in a compact and easy-to-use desktop device. Wireless networking lets you easily print from the cloud as well as from virtually any device.
Multifunction performance
Handle multiple tasks easily; print, scan, copy, and produce professional-quality documents from one device. Enjoy print speeds of up to 19 ppm with your first page out in 7.9 seconds. This printer makes it easy to copy both sides of identification cards onto one side of a document. And you can scan your files directly to PDF and email with preloaded business apps.
One of the best HP LaserJet printers available, as well as one of the best small laser printers for home use, the HP Colour LaserJet Pro MFP M283fdw is an efficient, wireless, and colour MFP that provides a high-quality colour. Save time with Smart Tasks in HP Smart App, and print and scan from your phone. This dynamic security-enabled printer offers faster, reliable connections with built-in dual-band Wi-Fi and strong security designed to help detect and stop attacks.
Enhance productivity with HP Smart App
This HP Colour LaserJet Pro MFP uses HP Smart App, the best-in-class mobile print app, to let you:
Quickly and easily print, scan, copy, and fax
The 50-page automatic document feeder helps you quickly and easily complete tasks, and automatic two-sided printing lets you speed through multipage documents. Print on virtually any kind of paper with this printer, including plain, coloured, preprinted, recycled, rough, glossy, bond, brochure, heavy, letterhead, light, and photo. In addition, you can print to transparencies, labels, envelopes, and cardstock.
Easily manage print, scan, copy, and fax documents at the device with an intuitive 2.7-inch colour graphic touch screen.
Protect your data
This printer uses Original HP Toner cartridges with Jet Intelligence, a technology that enables professional-quality pages, peak printing performance, and protection against counterfeits with innovative anti-fraud technology.
A dynamic security-enabled printer, the HP Colour LaserJet Pro MFP M283fdw helps protect your data with real-time threat detection and software validation. Detect, stop, and get notified about security breaches. It also has write-protected memory to help prevent malware intrusion.
The HP LaserJet Pro M118dw is a monochrome wireless laser printer that is one of the best compact laser printers for home use. Weighing at transportable 15.2 lbs, it’s designed for individuals as well as micro-and small-sized business owners and home office users who are looking for high-productivity features at a reasonable price. Produce professional and consistent two-sided documents, and print easily from your mobile device.
Print professionally, precisely, and plentifully
Produce professional-quality pages in high performance with precise black Original HP Toner cartridges that print up to 1,000 pages with bold blacks, sharp text, and crisp graphics. That’s up to 40% more than comparable in-class products. Run this printer affordably, as well, thanks to the included HP Original LaserJet imaging drum, which lasts up to 23,000 pages.
Speedy, easy to use
Print rapidly with speeds of up to 30 ppm with the first pages ready as quickly as 6.6 seconds and multiple pages with automatic duplex printing. This printer also has a high-capacity 250-sheet main input tray, a 150-sheet output tray, and a 10-sheet priority tray. Enjoy voice-activated printing with Amazon Alexa, Google Assistant, and Microsoft Cortana.
Wireless printing is a breeze with the HP Colour LaserJet Pro MFP M182nw, which offers faster and more reliable connections with dual-band WiFi that’s compatible with operations at 2.4 GHz and 5.0 GHz frequencies. Your documents will print at speeds of up to 17 ppm, and the first page out in black will be ready in 11.6 seconds, while the first colour page completes in 13.5 seconds.
Multiple connectivity options
Easily print from virtually anywhere. It’s Mopria™ Certified and supports many printing apps, including HP Smart App, HP ePrint, Apple AirPrint, and Mobile Apps. In addition to its wireless capability, this printer offers standard connectivity options, with a high-speed USB 2.0 port, and a built-in Fast Ethernet 10/100 Base-TX network port.
Print, copy and scan effortlessly
The HP Colour LaserJet Pro MFP M182nw is one of the best compact laser printers for home use. Effortlessly print, copy, and scan directly at the control panel. While this model is slightly heavier than the others on our list at 34.6 lbs, it takes up a relatively small footprint of 16.5-inches wide by 15-inches deep and 11.5-inches high.
This dynamic security-enabled printer uses Original HP Toner cartridges with anti-fraud JetIntelligence technology, so you can be assured that you’re enjoying the authentic cartridges that you paid for, along with the superior colour.
Whether you’re looking for a monochrome (black ink only) printer, a colour printer, or an MFP (or AiO printer), you’re sure to find the model you need among the compact wireless laser printers outlined above. However, the HP LaserJet Pro MFP M29w stands out as the best all-around compact laser printer from HP®.
