Thank you for visiting the THAILAND HP Store
Mon-Fri 9.00am - 6.00pm
Since its official release in 2011, Minecraft has taken the gaming world by storm. More than any game before it, the Mojang-developed title has inspired creativity among millions and millions of players.
In doing so, it’s inspired many gamers to look into new and improved laptops to optimize their gaming experience. When it’s time for you to narrow down your choices of the best HP laptops for Minecraft, there are several key criteria to keep in mind.
Although Minecraft is not a graphics-intensive game, it does require a relatively powerful laptop to run even at minimum settings. That means your Minecraft laptop requirements will need at least an Intel® Core™ i3 processor, 4GB of RAM, and either an AMD® Radeon™ R5 series or NVIDIA® GeForce 400 graphics card.
However, we recommend that you look at laptops that can run Minecraft with better specs. This will allow you to run Minecraft at higher settings and even potentially use Minecraft shaders to add more vibrancy to your game world. To do so, look for laptops with an Intel Core i5 processor, 8GB of RAM, and an NVIDIA GeForce 700 Series or AMD Radeon Rx 200 Series graphics card.
While it may seem that a Minecraft gaming laptop is a must, it’s actually not. Plenty of laptops can meet the recommended specs without being strictly for gaming. However, if you want to use advanced graphics settings, then we absolutely recommend a gaming laptop as the best laptop for playing Minecraft.
Ultimately, it is up to you whether you want to dig into advanced features like ray tracing to change the way you experience the game. Otherwise, you’ll be perfectly fine playing Minecraft on low or even medium settings.
Whether you’re just getting into Minecraft or you’ve been playing for years, the right laptop will make all the difference when it comes to immersing yourself in this unique, ever-expanding game. From more budget-minded laptops to those that can run newer titles at higher settings, here are our picks for the best HP laptops to play this one-of-a-kind experience.
One of the best gaming laptops on our list, the HP OMEN 15 15t-ek000 virtually guarantees that you can play Minecraft at the highest possible settings. It starts with an Intel Core i5 processor, 8GB of RAM, and the NVIDIA GeForce GTX 1650 graphics, but here’s the kicker - you can upgrade all of those to get the specs you crave. With a laptop like this, the chances of running into any frame rate issues or game crashes are basically non-existent.
With a 6-cell, 70.9 Wh Li-ion polymer battery, you'll be able to play Minecraft for hours and hours from just about anywhere. Plus, thanks to the HP OMEN Tempest Cooling technology, you won’t have to worry about temperature issues as you gather resources and build to your heart’s content.
Additional features:
15.6-inch diagonal FHD, IPS, anti-glare, micro-edge, WLED-backlit display
Audio by Bang & Olufsen on dual speakers with HP Audio Boost
Customizable 256GB PCIe® NVMe™ M.2 SSD
ENERGY STAR® certified and EPEAT® Silver registered
Built for productivity, the HP 470 G7 notebook PC is no slouch when it comes to gaming either. This is great news for Minecraft fans who also need a new laptop for work or general use. It comes standard with an Intel Core i5 processor as well as 8GB of RAM, which more than meets Minecraft's minimum settings recommendations.
The HP 470 G7 comes standard with integrated Intel UHD Graphics 620, which you can upgrade to discrete AMD Radeon 530 Graphics to run Minecraft on higher settings or even use mods. However you customize it, this is a strong midrange laptop for playing Minecraft.
17.3-inch diagonal, FHD, IPS, anti-glare, WLED-backlit display
720p HD camera
256GB PCIe NVMe SSD
HP Connection Optimizer, HP JumpStart, HP Support Assistant
DVD-Writer optical drive
2 USB 3.1 Gen 1 ports, 1 USB 2.0 port, 1 RJ-45 port, 1 headphone/microphone combo port, 1 HDMI 1.4 port
A general use high-performance laptop, the HP Pavilion 15z is equal parts stylish and powerful. With an incredible AMD Ryzen™ 7 3700U processor coupled with a Radeon Vega 10 Graphics card, you'll be able to render an instance of Minecraft any which way you like.
With approximately 8 hours of battery life, you'll also be able to play a full Minecraft session without having to plug in your laptop. While this laptop is not specifically geared toward gaming, its powerful specs guarantee that you'll be able to play Minecraft on it for years to come.
15.6-inch diagonal, micro-edge, WLED-backlit touch screen
512GB PCIe NVMe M.2 SSD
3-cell, 41 Wh Lithium-ion prismatic Battery
HP Wide Vision HD Camera with Dual digital microphone
Audio by Bang & Olufsen, dual speakers, HP Audio Boost
The HP ProBook 445 G7 notebook PC is a reliable, well-rounded choice for gaming and just about anything else you’d like to do. It starts with a 2nd generation AMD Ryzen™ processor and Integrated AMD Radeon Graphics, which are more than enough to play Minecraft in more casual settings. Or you can customize it with additional power if you’re really looking to push the way you experience the game.
Beyond its gaming capabilities, this notebook impresses because of its suite of privacy, security, and productivity features. With those specs and overall potential, this HP ProBook is a fantastic choice for those who want to work and play on their new laptop.
14-inch diagonal LED, anti-glare, HD display
Upgradeable 500GB 7200 RPM SATA hard drive
3-cell 45 WHr Long Life Battery
Stereo speakers with integrated microphone
Bundled software includes HP Connection Optimizer, HP Image Assistant, and HP Noise Cancellation Software
Integrated HD 720p IR webcam with a dual-microphone array
If you want a smooth frame rate, further render distances, and more attractive animations when playing Minecraft, look no further than the 15-inch HP Pavilion gaming laptop. This may just be one of the best laptops for Minecraft on our list.
It boasts high-grade graphics and processing power that are perfect for both gaming and multitasking. In addition to the upgradable 9th Generation Intel Core processor and NVIDIA GeForce graphics card, it uses a dual fan system with thermal cooling technology to keep your device running smoothly even during the longest gaming sessions. With that kind of power, you can also dip into the world of Minecraft shaders and other mods without experiencing gameplay issues.
Upgradeable 8GB DDR4-2666 SDRAM
Upgradeable 256GB PCIe NVMe M.2 SSD
Bang & Olufsen, dual speakers, HP Audio Boost 2.0
3-cell, 52.5 Wh Lithium-ion prismatic Battery
The HP laptop - 15-dw2697nr prides itself on its portability and compact size, so it’s another top pick for playing Minecraft on-the-go. And like other entries on our list, it’s certainly powerful enough to handle more than just your favourite game.
It comes loaded with a generous 12GB of SDRAM and Intel UHD Graphics, both of which you can upgrade at checkout. The 15-inch HP laptop also comes with a long-life battery that you can rely on for more than just gaming, turning this into a solid entertainment device as well.
15.6-inch diagonal, HD, SVA, BrightView, micro-edge, WLED-backlit display
Upgrade to 16GB Intel Optane™ memory
3-cell, 41 Wh Li-ion battery
HP TrueVision HD Camera with integrated dual array digital microphone
Full-size, island-style, ash silver keyboard with numeric keypad
Be the envy of everyone with the HP ENVY x360 touch laptop. It’s built to handle Minecraft exceptionally on nearly any setting with its powerful AMD Ryzen™ processor coupled with AMD Radeon Graphics. It also comes standard with 8GB of SDRAM, which you can customize up to 16GB of SDRAM.
Those features will help you avoid frame rate dips or game crashes, but this HP ENVY can do so much more than power your Minecraft sessions. Thanks to the 360-degree hinge and touch screen, you can transform this laptop into a tablet and get hands-on with everything else you’re doing with your new favourite device.
15.6-inch diagonal FHD, IPS, micro-edge WLED-backlit, multitouch-enabled, edge-to-edge glass display
3-cell, 51 Wh Li-ion polymer battery
Audio by Bang & Olufsen, 3 speakers, HP Audio Boost
HP Wide Vision HD Camera with camera shutter and integrated dual array digital microphone
If you're looking for a Minecraft gaming laptop you can use while travelling or commuting, the 13-inch HP Spectre x360 13-ap0042nr is for you. This laptop isn’t specifically built for gaming, but the included 4-cell, 61 Wh Li-ion battery gives it up to 14 hours and 30 minutes of power.
When you’re deep into a long session of Minecraft, it’s nice to know you won't even have to think of plugging in. Plus, it weighs less than 3 lbs, so it’s perfect to take with you on a plane, car, or bus ride.
This HP Spectre also comes with an Intel Core i5 processor and integrated Intel UHD Graphics 620 so you can run Minecraft comfortably on medium settings. Not only that, but you’ll have all the time in the world to do so with that impressive battery life.
8GB DDR4-2400 SDRAM
Audio by Bang & Olufsen; 3 speakers; HP Audio Boost
The HP OMEN 15t laptop is one of the best gaming laptops on the market, which makes it a perfect choice for playing Minecraft. You'll be able to use shaders and mods to your heart's content, and you’ll do it without ever worrying about any performance-based issues with the game.
This HP OMEN is more than just a Minecraft machine, however, because it’s built to handle the latest games on the market. If you want a machine that can play the best-looking games, we strongly recommend you consider this Minecraft gaming laptop. It more than earns its rank as a portable powerhouse.
15.6-inch diagonal, FHD, 60 Hz display, upgradeable to 4K
Intel Core i7 processor, upgradeable to i9m
Up to 32GB DDR4-2933 SDRAM
6-cell, 69 Wh Li-ion polymer
A laptop that is ideal for creatives, the HP Pavilion x360 14t has all the specs you need in a laptop for playing Minecraft. It starts with a 10th Generation Intel Core i5 processor, which you can upgrade up to an i7 processor to push the settings up a notch. You also get 8GB of RAM and integrated Intel UHD graphics, both of which you can customize to really get into your favourite game.
More than just pure power, the 14-inch HP Pavilion x360 is portable as well. Depending on how you customize your build, it starts at a mere 3.49 lbs and is less than 13 inches wide, a great combo for crafting on-the-go.
14-inch diagonal, HD, SVA, micro-edge, WLED-backlit, multitouch display
1TB 5400 rpm SATA
16GB Intel Optane memory
3-cell, 41 Wh Lithium-ion prismatic battery
When it comes to choosing a laptop for Minecraft, it’s good to know you have a lot of options. While many of the picks on this list will let you play Minecraft, we recommend the HP Pavilion 15z for those who want an overall high-performance laptop. It’s a great buy that’ll allow you to spend hours and hours immersed in the world of Minecraft without any technical issues.
