Thank you for visiting the THAILAND HP Store
Mon-Fri 9.00am - 6.00pm
Your Minecraft experience is shaped by where you choose to spawn, which is why it is so important to choose the right seed for you. Minecraft seeds are what make the game interesting and present new challenges in gameplay, whether you prefer a pastoral environment or one made of ice and snow.
However, some are better than others, and knowing what is available can make all the difference in how your gameplay experience is structured.
It may seem like there’s an unlimited supply of seeds and the truth is that gamers are always creating new worlds to explore. Sifting through all of them can actually take away from your actual playtime, so it’s good to know which options are most appealing - and the most fun.
Minecraft seeds are codes that generate the worlds that you play in. They cover a wide variety of places, including murky dungeons and landscapes with gorgeous views. Once implemented, these codes create a world in which you can build and explore.
They can change the nature of your gameplay and the type of creations you want to build with your setting. You can also choose to play the same seed with a friend to see how your experiences may differ.
While some players enjoy jumping into a randomly generated world, others like to have a bit more control over the type of game they are playing or the types of resources they can access.
Custom Minecraft seeds allow you to personalize the entire Minecraft experience. Seeds customize the game for you, and they provide a more dedicated plan about what you are going to build and what you can accomplish during gameplay.
To choose a seed, enter the code associated with that seed. Almost all codes are a series of numbers in either negative or positive values. If you do not use a certain value, the game will automatically use a random seed that you haven't chosen.
If you want to search for some new seeds to use, then make sure to check out the iOS and Android app Seeds Pro. It's a community-based app that allows you to share seeds with friends online and discuss them in detail.
Best of all, you can link your Minecraft Pocket Edition (PE) account so you can easily download the best Minecraft PE seeds created by other users.
If you’re just starting out in Minecraft, creating a new world in the game is much easier than you may think. First, head to the World Generator, where you can consistently upload the same biomes and structures each time. Minecraft PE also allows you to create worlds separate from the random ones automatically generated by the game.
Minecraft has a few different forms of gameplay, and seeds work a little differently on each type. More people play Minecraft on console than those on PC and mobile, meaning that each base has its own fandom and has various required specs.
The main difference between the PC and PE versions is that the latter’s worlds are only 256 x 256 blocks in size, making it more difficult to create a variety of worlds for players. As of 2015, sharing seeds either through mobile or PC has been pretty much the same, but you may need alternative codes depending on which system you use.
For consoles, you will need to determine which one you are playing before proceeding. The Minecraft PS4 seeds differ from the Minecraft PS3 seeds or Minecraft Xbox 360 seeds, for example, and there is no guarantee that you will spawn what you are looking for if you use the same codes across platforms.
Before entering a seed, make sure that it is specifically designed for your platform so that you end up with the compatible seed ready to play. There also aren't nearly as many seeds for consoles as there are for the other editions, but more are being created all the time.
You also want to make sure that your system is running the correct version of Minecraft so it can run the seeds you want. If in doubt, double-check to make sure.
You may actually need to revert back to legacy versions of the game in order to choose the seeds you want, although it is extremely easy to do if you need to.
Determining the best Minecraft seeds is no easy task, especially because it can come down to personal opinion depending on how you play and what you enjoy doing in the game.
However, certain seeds are among the cream of the crop based on the number of times entered and their continued popularity. Here are some cool Minecraft seeds you can try next time you play.
Buried treasure and hidden loot make this seed immediately exciting. With several islands available to explore, you have the opportunity to collect a number of cool items, including 2 enchanted tunics, 6 gold nuggets, 8 gold ingots, an iron sword, and a lot more.
With 2 shipwrecks (the second offers the most rewards), you’ll have plenty of loot to search for. Look at the buried treasure map so you know how to get back to where you spawned.
Welcome to the jungle! You'll be spawned right near a temple in a convenient place where you can cross over to a desert or a jungle biome - the choice is yours. You'll need to explore thoroughly for items, and beware of the pillagers that take over this area.
Arm yourself early on and you should be all set to experience an awesome survival game. Also, don't forget to check out the river, ocean, and mountains for additional items.
This beautiful and icy Minecraft seed offers a unique adventure and a bit of a challenge, too. Your character will spawn on the edge of a forest. From there, head toward the frozen river where you will start to see ice spikes coming up from the ground.
You may also see some polar bears and rabbits roaming around, but don't worry, they're harmless. Gather some resources and begin building in this chilly and intriguing seed.
If you love animals (especially the voxel-shaped, Minecraft animals), this is the seed for you. You'll spawn right in the middle of a farm featuring horses, pigs, sheep, and ducks.
Make sure to gather your resources from the nearby savanna biome in order to get the coal and stone you need in order to build your farm. After you start your furnace, you're ready to let your imagination go wild and corral those animals.
You'll spawn right near a small village that’s close to a number of different biomes including plains, and ocean, and forests. The world is home to a large ravine, which is where you will find the ore you need to craft (ladders are highly recommended). Part of the adventure is interacting with this challenging world and seeing how you can work around the massive split in the earth as you build.
With 2 savanna villages located in this seed, you’ll have access to plenty of resources so you can build to your heart's content. To the right, you have a "large ocean savanna village," which is a good place to start looking for items and resources.
Once you have gathered what you need, you may want to expand to the plains biome or head to the "mountain savanna village." There, you'll find wood for building your next masterpiece.
Have you ever wanted to live on a deserted island filled with horses? This seed spawns you on a small island where - you guessed it - your only company is a herd of wild horses. There’s also a shipwreck nearby where you can gather some unique items like a compass and a buried treasure map.
This seed is definitely geared more toward exploration rather than building. But, you can have a lot of fun searching for treasure and interacting with the friendly horses on the island, making it one of the best Minecraft survival seeds.
As you can imagine from its name, this seed features a shipwreck and an iceberg as its main focal points. But there are some unexpected features worth checking out as well. You'll find a nearby island with a lush jungle and a giant pit where you can find the resources necessary to build your creations.
Unfortunately, this seed does not come with a certain famous song by Celine Dion, so you will have to add that yourself.
Note: The loot is different in this seed depending on your platform.
You will arrive on the west side of a jungle island where you can then enter a temple filled with some amazing loot. Along with 2 diamonds to gather, there are some...bones? Nonetheless, this is a great spot to begin building your new empire or simply explore the jungle. If you are looking for some more resources, head past the temple to the ocean, where you can find a mine and cave spider spawners.
Looking for one of the newest seeds that takes full advantage of version 1.14? You'll want to check out "The Pillager Outpost," which adds some stealth elements along with the world you have spawned.
The best thing you can do is sneak up to the top of the tower past the pillagers equipped with crossbows. Avoid getting caught and you’ll be able to access your very own crossbow, which is located in the chest.
There is a reason that Minecraft has remained so immensely popular since its release in 2009. Along with its unique combination of creativity and exploration, this timeless classic is constantly undergoing changes and updates, often through the variety of good Minecraft seeds that are available today.
For our picks, some of the more innovative seeds that allow players to have the most exploration are The Jungle Temple of Diamonds and Bones and Savannah Villages on the Great Plains.
These seeds offer a variety of loot and construction options, and they allow you to explore for hours upon hours. With these recommended seeds, you can experience an entirely new take on Minecraft and make it a new experience every time you play.
