Thank you for visiting the THAILAND HP Store
It looks like you're in United States, would you prefer to shop in that country or continue exploring the THAILAND HP Store?
Mon-Fri 9.00am - 6.00pm
You press the power button on your laptop... and nothing happens.
There are few more frustrating technological hiccups than when your laptop won’t turn on. However, you don’t have to resign yourself to the idea that your laptop has met an untimely death. We’ll show you some ways to assess what’s wrong and fix it.
If your laptop won’t power up, a faulty power supply, failed hardware, or a malfunctioning screen could be to blame [1]. In many cases, you may be able to resolve the problem yourself by ordering replacement parts or adjusting your laptop’s configuration.
But if your laptop is older and the problem is an expensive hardware issue, it may make be the best time to buy a new laptop.
If your HP laptop won’t turn on even when plugged in, start by checking the power supply. There are quite a few issues you could have with the power supply.
For example, the problem could be as simple as having the wrong charging cord which means you aren’t getting the proper voltage, or it could be that the power supply has failed [2].
One other possible solution to test out is to replace the CMOS battery which stores the BIOS settings in the motherboard [3]. This is especially true if you're running an older laptop that is off a lot or used with the main battery removed. A new CMOS battery is very budget-friendly to replace.
Pro tip: Make sure that the cables are all properly connected. This might seem simple and obvious but most issues with a laptop that won’t turn on stem from a power supply issue. A loose or unplugged power cable means your computer isn’t getting the juice it needs to run.
If your power supply is working, you will need to troubleshoot further.
If your laptop starts up but there isn’t an image, the LCD panel could be broken. It’s not impossible to fix a broken screen, you can read our article here about how to do so. But if your laptop is an older model it might make more sense to simply replace your entire laptop.
If you have left a memory card, DVD, or USB drive in your notebook, this could be a reason why your laptop doesn’t power on.
It might be getting “stuck” because the BIOS may be trying to boot from a removable storage device. Remove all USB drives and other devices and try to boot up your computer.
A rescue disc allows you to boot your computer and fix any issues you may be having with a Windows operating system [5]. If a virus is the culprit behind your computer problems, the rescue disc will find it via scanning tools so you can remove the offending malware.
If your HP laptop won’t turn on you might still be able to get your laptop working in safe mode [6]. Safe mode allows you to uninstall new programs or drivers that could be affecting your laptop. It also allows you to create a new user account if your original account has been corrupted.
The last step when diagnosing power issues is to check your hardware. If you’ve recently installed hardware like a new RAM kit, that could be the cause of your boot issues. Remove and reinstall your new hardware and try to boot again.
Unfortunately, sometimes the hardware in your laptop such as your hard drive simply fails and there is no easy fix. If you hear a clicking noise or the drive spinning but then powering down, this is a telltale sign your hard drive has failed [7]. In most cases, this means you’ll need to simply replace your hard drive.
In instances like this, it is smart to have an external hard drive so you can back up any files you may need.
Answering the question, “Why won’t my laptop turn on?” might seem intimidating to figure out at first. Laptops make our lives more convenient by providing us with mobile computing options that fit any lifestyle.
But if you rely on a laptop for your work, school, and daily multitasking, any major issue can throw a wrench in your productivity.
If you find that your laptop won’t turn on, don’t panic. It’s likely a power supply issue that you can troubleshoot and fix. Even if it’s a more complicated issue, there are still budget-friendly ways to test and assess the problem.
And if nothing works, a new desktop computer may be the answer to solving your technology woes.
[1] Tech Advisor; How to Fix a Computer that Won’t Boot
[2] LifeWire; How to Fix a Computer that Shows No Sign of Power
[3] DeskDecode; CMOS Battery
[4] TechWalla; I Dropped My Laptop and Now my Screen Doesn't Work
[5] Lifehacker, Five Best System Rescue Disks
[6] Windows Central; How to Fix Blackscreen Problems on Windows 10
[7] Make Use Of; 5 Signs Your Hard Drive Lifetime is Ending
