Thank you for visiting the THAILAND HP Store
Mon-Fri 9.00am - 6.00pm
Whether you primarily use your laptop for business, gaming, or school, there may be a time when you want it to do double-duty as a second screen for your computer. Setting up your laptop as a monitor takes an understanding of your connection options, the operating system, and a few adjustments to your screen. It is affordable and is considered one of the lesser-known features that helps make Windows 10 a favorite among computer users.
If you’re ready to do more with the equipment you already have and save money over buying a dedicated second monitor, this strategy is for you. Here’s how to get the best results when completing the setup of a laptop monitor as a second screen for your home or office.
Very few people consider a laptop as a second monitor when they first purchase one, but it’s nice to know you have it as an option. Laptops that no longer function at peak performance are good candidates to be used as a display, as long as the screen and operating system still function. It’s no longer necessary to put your slow laptop on a shelf where it will collect dust or recycle it.
There are so many ways to improve your workflow by connecting a second monitor. Here are the most popular uses:
Any time you’ve had to toggle between two applications, software tools, or browser windows, you may have benefited from having a second (or even third) display. Once you start using one, you’ll also come up with new uses that may not have been mentioned.
Remember that you are using the laptop screen as a monitor, so it’s not necessary for every component on your laptop to be in perfect working order to be a candidate as an additional monitor. Even if you don’t have access to all of the features, a laptop with a working display makes it a perfect accessory for the busy gamer or business professional.
Keep in mind that the following tips work for Windows-based laptops and desktops only. If you run macOS you will need to find specific instructions for using your Apple laptop as an external monitor.
The supplies you need include:
Microsoft 10’s built-in Miracast technology makes the act of connecting your laptop easy for anyone. You won’t need any cords, connectors, or wireless dongles, provided you are running the most updated operating system on both machines.
You will not need a second cable or cord to connect the primary computer to the laptop, and any cables that promise to do this likely won’t work. The video ports on a laptop are almost always for output only and don’t allow for audio/visual information to come into the laptop from an outside source. You should only need what’s listed above.
You’ll only need to have the primary computer ready, along with the laptop you want to use as a second screen. Make sure both devices have the latest Microsoft Windows version 10 or higher. You may also need to be logged in as an administrator.
Set up takes minutes if your Windows software is updated and if both of your devices are turned on and discoverable. Perform these two quick steps to begin:
After you’ve selected all the relevant options, make a note of the PC name at the bottom of the settings window. This is the name you’ll need when choosing which device to connect to later.
Now that your laptop is set up for projection:
While a dual monitor setup with a laptop can work very well for several uses, it won’t be ideal for every situation. Gamers, for example, will find a second screen useful for viewing walkthrough documents or real-time chat. Just keep in mind that it’s not ideal for online or graphics-heavy gaming. There can be significant lag when transferring data to the second screen, so only project your gaming graphics to the original desktop monitor.
If you have an older version of Windows, you may still be able to use the Extend feature to display on a laptop screen. It’s also possible to use any modern monitor or TV as a second screen by purchasing a Microsoft Wireless Display Adapter. This plugs into your screen’s USB and HDMI ports to create a connection to your original desktop or device. If you go this route, you won’t need an internet connection to project to the second screen.
For even more multi-tasking functionality, don’t forget to select “Allow Input” when you’re connecting from the main desktop to the laptop. By checking this box, you give access to the second laptop for using a touch screen, pen, keyboard, and more. It’s one way for two users to work together on one device, including collaborating on programming projects or design work.
For those who have always wondered how to use a laptop as a monitor, these easy steps should get you working more efficiently in no time. Giving a laptop, even one that doesn’t run perfectly, new life as a monitor is also a responsible way to keep a device out of the landfill. With many of today’s laptops offering better resolution, larger screen sizes, and bolder graphics, it makes sense to incorporate their high-tech displays into your workflow.
