Thank you for visiting the THAILAND HP Store
Mon-Fri 9.00am - 6.00pm
After your printer has been used for a number of projects, it’s common for users to begin running into quality issues. This can include streaking, fading, or even missing text on your prints, and it can often be the result of a dirty printhead.
What is a printhead? The answer is simpler than you may imagine. The printhead is a component in a printer that houses ink cartridges. It’s typically located under the cover of your printer, and it can become clogged with ink over time.
No matter which type of cartridge you use - compatible, reusable, or branded - ink can dry out and cause problems with the appearance of your prints. If this is left unaddressed, then your printer has the potential to break down and may have to be replaced entirely.
A printhead can usually be cleaned in one of two ways: through software on your PC or manually by taking out the printhead.
Here’s a quick rundown of how you can clean your printer head from the HP experts:
It’s important to remember that these parts are delicate. If you choose to perform the repair yourself, you should be careful not to damage the contacts on both the printhead and your ink cartridges. If they’re damaged, it’s likely that you’ll need to take the printer to a professional for repair.
Inkjet printers function by spraying tiny droplets of liquid ink over the surface of the paper. With smaller droplets, you can make sharper images. Ink comes in three major colors (cyan, yellow, and magenta) as well as black. By combining the colors together in a specific pattern, the other shades of the color palette are formed.
To create crisp, clear prints, the ink must be applied with precision. One way to ensure this is by getting the best home printer. Another is to be sure you are only using the highest-quality inks. When you purchase an HP inkjet printer, you are getting both of these - as long as you take care of the printer and only purchase genuine HP Ink products.
A printhead can become dirty after it has been sitting idle for a period of time. It’s recommended that you perform a few print jobs each month in order to maintain print quality and to keep the ink from drying in the cartridges. However, even if you print a few times a week, you may still find yourself dealing with HP printhead problems.
You’ll know fairly quickly if your printhead is causing you problems. If your PC or the LCD screen on your printer is telling you that your ink cartridges are full but no ink is passing through to the paper, then it’s most likely that you are dealing with a clogged printhead. Blurry documents and images that appear faded are also signs that it’s time to remove the excess ink.
Before you start the process of cleaning, you’ll need to perform a nozzle check to make sure it’s actually causing the issues. You can usually do this from either your computer or your printer on newer models. This can help you avoid touching the printhead and damaging the contacts on either the ink cartridges or the printhead itself.
You wouldn’t drive your car more than 5,000 miles without an oil change, so why would you run your printer for an extended period of time without completing regular maintenance tasks? You wouldn’t.
Cleaning the printhead is just one thing you can do to ensure smooth operation. It’s also one of the easiest tasks to do at your home or office.
Today’s HP printers are equipped with innovative software that can sense the first signs of trouble and automatically put the printer into maintenance mode. This usually includes tasks such as print head cleaning and alignment.
If you haven’t printed in some time, however, it may be necessary to perform an extra step or two to clean ink heads on an HP printer.
You may be notified by your printing software or the display on the printer itself that maintenance is needed. Another way to tell that your print heads are dirty is if your print jobs come out partially printed or streaky. If your printer display says that you’re low on ink but you have a full cartridge, this may also be a sign of a dirty printhead.
Whether the printer notifies you or you suspect it’s an issue from the quality of your prints, don’t do any more printing until you’ve taken the following steps.
First, make sure that you are using genuine HP printer cartridges. HP printers are designed to maximize efficiency and quality with HP original components. Check to see that your cartridge is an HP ink product and is the right fit for your model.
If you see that the cartridge shows sign of damage, has exploded, or doesn’t fit correctly, remove the cartridge and insert a new one. Wait for the printer to go through the automated maintenance tasks for the new cartridge and try printing again.
If you have tried cleaning the printhead through the software but you’re still noticing problems with your print jobs, then you may need to manually clean it. Again, it’s important to be careful when dealing with the ink cartridges and the printhead because they’re easily damaged.
If you’re still experiencing quality issues or printhead errors, then there may be other problems at play. Before taking any other actions, it’s recommended that you clean the printhead and ink cartridges four or five more times.
Also, leave your printer unplugged overnight and double check the nozzle on your ink cartridges to make sure they aren’t full. You want to give everything a chance to dry out before cleaning.
Old or damaged ink cartridges can also cause issues with your printer’s performance. If the above steps haven’t fixed the problem, replacing your cartridges could be the answer.
Go through the process of cleaning your printhead’s contacts again before you insert new printer cartridges. After the initialization process, try printing another document to see if your images are clear and that there is no streaking or fading.
If there are still problems with your printer, it may be time to take it into a repair shop that specifically works on the brand you have purchased.
A skilled HP expert may be able to identify the problem and fix your printhead so you no longer have issues with your print jobs. He or she can also make recommendations for keeping your printer clean so you can avoid running into similar problems in the future.
Also, make sure you avoid using a harsh cleaner on your printer or taking it apart. You don’t want to do anything that would void the warranty on either your printer or the HP ink cartridge.
HP representatives are there to help with the best printhead cleaning solution for your particular model of printer and can offer solutions or repair options to get you printing again quickly.
