Thank you for visiting the THAILAND HP Store
Mon-Fri 9.00am - 6.00pm
Many of our storage devices and computer accessories use a USB connection to function. But what happens if your computer doesn’t recognize your USB? While a common problem, it’s usually easily fixed. Learn how to troubleshoot this issue in our step-by-step guide.
If you get an error message alerting you that there is a USB device not recognized, it can be frustrating. We rely on our accessories to help us stay productive. In the case of a storage device that produces this error, for example, you won't be able to access important files. The reasons for the error can be a driver problem, a damaged USB device, or improper settings. Some of these issues are easier to fix than others.
If your desktop computer or laptop doesn’t recognize your USB devices, don’t be alarmed. While inconvenient, it shouldn’t be a permanent problem. It’s also one of the easier problems to fix so you can get back to work in no time.
Let’s face it. There’s some truth to the old IT adage that many computer glitches can be fixed by turning your computer off and on again. An unrecognized USB device can sometimes be the result of an error that the computer will resolve upon restart.
Be sure you safely close out of all programs and use the Start Menu to restart your PC. This may resolve your USB recognition error.
Is your computer getting older? Do you frequently use the same USB port out of convenience? Try to use the USB device in another port. If you don't have the same issues, it's probably a physical defect in your favourite port. You can choose to have it fixed or start relying on the new location for plugging in accessories.
There’s a small chance that your USB device is damaged and not your PC. Try inserting the device into another computer. Is there still an error message? It’s possible that your device has physical damage and isn’t usable.
A much-needed Windows update could fix this problem because many updates include drivers as well. See that you have the latest Microsoft updates by following these steps:
Your computer will let you know if it needs to update and will ask for permission to install and restart.
Drivers seem to be the root of many computer problems, and USB device errors are no exception. In Windows 10, you can attempt to solve driver errors by updating your device driver. To do this, follow these steps:
Windows should start the update on its own and let you know when it's finished. Try using your USB device again to see if it works.
If you’re still not getting the desired result, changing a small setting could help:
You may need to restart your computer for this to take effect.
While it’s not entirely clear why Fast Startup in Windows 10 can cause errors, disabling this feature has created a positive outcome for many users with USB issues.
Try your USB device again.
While this is a common problem that will likely happen again in the future, there are a few steps you can take to limit the potential.
If you don’t see a message that it’s safe, try closing out all programs, windows, or folders that may still be in use by the USB and try again. You may also have to restart your computer with the device still inserted and try ejecting it again.
USB devices are an important part of how we use our computers. Without them, we would have limited options for the storage, keyboard, mouse, and sound devices we enjoy the most. Fixing a USB error takes a bit of time, but having the full features of your PC or laptop is worth the effort.
