Thank you for visiting the THAILAND HP Store
Mon-Fri 9.00am - 6.00pm
Using a scanner is a vital tech skill. From storing your child’s favourite drawing to the cloud to getting a clear copy of a legal document so you can send it by fax, the perfect scan is essential. If you own an HP scanner and have questions about how to use it, this step-by-step tutorial can get you scanning documents in no time.
Your HP device is designed for an easy scan-to-computer process, but there are some steps that help make the process go more smoothly. Follow these tips for the best results:
Note: If you have a multiple-page document that you want saved as a single file, choose to save it as a PDF file. JPEG or other file types will save each page as an individual file.
If you cannot find HP Scan software for your device, it may be because it is too old. Scanners and multifunction printers from before 2010 use the HP Solution Center Software. The steps for scanning are similar.
Once scanned, the document can be easily uploaded to the cloud for storage. You can also upload it as an email attachment and send it to anyone in your email contacts list. If saved as a common file format, such as PDF or JPEG, you can also send it to your friends or family through social media or text.
There’s an easier way to scan to email as well. Start by making sure your email is configured to be used with a local email client, such as Windows Mail, Microsoft Outlook, or Mozilla Thunderbird. Once set up, you can select Scan to email as an option when scanning through the HP Scan software in step 4 above. Your saved scan will be sent to your local email program to complete the final steps.
Scanning is most often used to create an image of a photo or document, but what if you want to know how to scan a document into Word so you can edit it later? By choosing to use the Optical Character Recognition (OCR) software that comes with your HP device, you can convert the letters from an image file to text. To use this feature, choose Save as Editable Text (OCR) as the output for your scanned file.
If your printer or scanner doesn't come with this feature, you can purchase third-party OCR software to take scanned PDF files and convert them to text.
If you have an HP all-in-one or multifunction printer that includes a scanner and fax, then you can skip a few steps when scanning documents to send via fax. Instead of scanning to a computer, you can simply use the fax function to scan and then fax automatically. You’ll need updated software and a connection to a phone line to do this. In the end, you can save significant time by having a printer that does it all from one location.
For best results, don’t use the feeder tray to scan photographs because they can get caught in the mechanism. If you have a document that’s larger than what the scanner bed or feeder tray will hold, use the HP Smart app to scan with your smartphone, tablet, or other mobile device. This also works to scan items with your computer webcam.
If the file sizes for your scanned items are too large, you can adjust the resolution to get a smaller file size. This is useful when emailing scans because many email servers can’t handle file sizes that are more than a few megabytes.
If you weren't sure how to use a scanner before, these tips should have you on the right track. While each HP model will have slightly different instructions for capturing the right quality of the scan, the software included with your device is designed to take the guesswork out of the process.
