Thank you for visiting the THAILAND HP Store
Mon-Fri 9.00am - 6.00pm
In today’s fast-paced business environment in Thailand, the ability to print documents and photos from your smartphone is invaluable. Whether you’re a busy professional in Bangkok or a student in Chiang Mai, HP’s mobile printing solutions for Android can keep you connected to your printer, even when you’re on the go. Let’s explore how to print from an Android phone in Thailand.
Mobile printing has come a long way since the early days of home printers. Instead of being tethered to your device with a cable, you can now print wirelessly using the internet. There’s an important distinction between wireless printing and mobile printing:
Wireless printing uses a WiFi connection to send print jobs.
Mobile printing allows you to print from portable devices like smartphones or tablets.
Mobile printing is slightly more complex, as it enables your phone to communicate with your printer even when you’re not in the same room or on the same WiFi network. Most HP printers support mobile printing from Android devices, offering flexibility for users across Thailand.
Many HP printers allow you to print from your Android device when connected to the same WiFi network. This method works well for popular devices in Thailand, such as:
Samsung Galaxy smartphones
Google Pixel devices
Connect your Android device and printer to the same WiFi network.
Download the HP Print Service Plugin on your Android device from the Google Play Store.
Use the drop-down menus to print from supported apps like Drive, Excel, Chrome, Adobe apps, Gmail, and PowerPoint.
For situations where a shared WiFi network isn’t available, such as in a cafe or coworking space in Thailand, you can use WiFi Direct. Most HP printers manufactured after 2014 come equipped with this feature.
Download and install the HP Print Service Plugin from the Google Play Store.
Locate your printer’s unique WiFi Direct name and password.
Open the item you want to print and tap the menu icon, then select “Print.”
Choose your WiFi Direct printer from the list and enter the password.
Confirm the selection on your printer and wait for the connection to complete.
Tap “Print” on your device to start printing.
For those times when you need to print a document to your office in Bangkok while you’re traveling in Phuket, HP ePrint is the solution. This feature assigns a unique email address to compatible HP printers, allowing you to send print jobs from anywhere with an internet connection.
Find your printer’s email address and activate web services.
On your Android device, open the document or photo you want to print.
Use the share function to email the item to your printer’s email address.
Your printer will automatically print the emailed document or photo.
For a comprehensive mobile printing experience in Thailand, the HP Smart app is an excellent choice. Available for download from the Google Play Store, HP Smart offers a user-friendly interface for printing, scanning, and managing your HP printer.
To get started with HP Smart in Thailand:
Download HP Smart from the Google Play Store.
Ensure your Android device and printer are on the same WiFi network.
Open HP Smart and add your printer.
Use the app to print photos from social media, scan documents with your phone’s camera, or order ink supplies.
For those in Thailand looking for a versatile printer with mobile printing capabilities, consider these options:
The HP Smart Tank 750 All-in-One Printer is an excellent choice for Thai users who need a reliable, high-volume printing solution with mobile capabilities.
Print, Scan, Copy functionality
Automatic duplex printing
2.4/5G dual band WiFi and WiFi Direct support
Recommended monthly volume of 400 to 800 pages
This printer is perfect for Thai households or small businesses that require frequent printing and want the convenience of mobile printing options.
For businesses in Thailand that need fast, high-quality printing with mobile capabilities, the HP LaserJet Pro 4003dw is an excellent choice.
Monochrome laser printing
Auto-duplex printing
Dual-band WiFi connectivity
Recommended monthly volume of 750 to 4,000 pages
This printer is ideal for busy offices in Thailand that require reliable, high-speed printing with the flexibility of mobile printing options.
Mobile printing from Android devices offers convenience and flexibility for users across Thailand. Whether you’re using WiFi, WiFi Direct, HP ePrint, or the HP Smart app, HP provides multiple ways to stay connected to your printer. By choosing a compatible HP printer and utilizing these mobile printing methods, you can enhance your productivity and streamline your workflow, no matter where you are in Thailand.
For more information on HP printers and mobile printing solutions available in Thailand, visit our HP Printers page or explore our range of Business Printers for professional-grade options.
