HP TECH TAKES /...
Exploring today's technology for tomorrow's possibilities
HPImage
9 Ways to Charge Your Laptop Without a Charger
Zach Cabading
Reading time: 5 minutes
When your laptop battery dies and you don’t have your charger, it can bring your workday to an abrupt halt. Whether you’ve forgotten your charger at home or your laptop’s not charging properly, there are several reliable solutions. This comprehensive guide explores proven methods to charge your laptop without its original charger, plus essential troubleshooting steps for common charging problems.
From USB-C charging to power banks, and even how to charge your laptop in a car, we’ll cover all the alternative methods to keep your laptop powered up when you need it most. We’ll also address what to do when your laptop’s not charging and how to resolve charging issues effectively.
Understanding Your Laptop’s Power Requirements
Before attempting any alternative charging method, you need to understand your device’s specific power needs. This is especially important when your laptop battery is not charging or you’re seeking alternative power solutions.
Check Your Power Specifications
Look on your original charger or laptop for these specifications:
  • Input voltage (typically 100-240V)
  • Output voltage (commonly 19-20V for laptops)
  • Amperage requirements
  • Wattage needs (often 45W, 65W, or higher)
Using a charger with incorrect specifications can damage your laptop or provide insufficient power. Always verify compatibility before connecting any alternative power source.
Quick Solutions When Your Laptop Won’t Charge
Before exploring alternative charging methods, let’s verify whether you’re dealing with a simple charging issue or a more complex battery problem.
1. Verify Your Power Source
  • Test the power outlet with another device
  • Try a different outlet
  • Check your surge protector
  • Ensure all connections are tight
  • Inspect cables for damage
2. Check Battery Health Status
  • Click battery icon > Battery settings
  • Look for health warnings and cycle counts
  • Monitor temperature and charging behavior
Alternative Methods to Charge Laptop Without Charger
Now that you understand your laptop’s power requirements, let’s explore each method to charge your laptop without its original charger. Whether you need to charge your laptop in your car or use a phone charger in an emergency, these proven solutions can keep you powered up.
Method 1: How to Charge Laptop with USB-C
USB-C charging is one of the most reliable ways to charge a laptop without its original charger. Here’s how to use this method effectively:
1. Check USB-C Port Compatibility
  • Locate the USB-C port on your laptop
  • Look for a charging symbol near the port
  • Check your laptop manual for USB-C charging support
  • Verify Power Delivery (PD) compatibility
2. Use Proper Equipment
  • Connect a Power Delivery certified cable
  • Use a compatible power source
  • Check for charging indicator lights
  • Monitor charging speed
3. Optimize USB-C Charging
  • Close power-hungry programs
  • Reduce screen brightness
  • Enable battery saver mode
  • Ensure proper ventilation
  • Position laptop for best airflow
Method 2: How to Charge Laptop with Power Bank
When your laptop’s not charging and you’re away from power outlets, a power bank can be your best solution:
1. Initial Setup
  • Start with a fully charged power bank
  • Place on a flat, cool surface
  • Remove protective port covers
  • Check cable compatibility
2. Power Bank Usage Tips
  • Begin charging before battery gets critically low
  • Use highest-rated USB-C port available
  • Avoid connecting multiple devices
  • Monitor charging progress
  • Keep power bank ventilated
3. Maximize Power Bank Life
  • Disconnect when charging completes
  • Store at moderate temperatures
  • Maintain 20-80% charge level
  • Use regularly to prevent battery degradation
Method 3: How to Charge Laptop in Car
Car charging offers a reliable solution when you’re on the road. Here’s how to charge your laptop in car safely:
1. Using Power Inverter Method
  • Park in well-ventilated area
  • Connect inverter to 12V outlet
  • Start car before connecting laptop
  • Monitor car battery level
  • Take charging breaks
2. USB-C Car Charger Approach
  • Use compatible car charger
  • Connect directly to car outlet
  • Avoid extension cords
  • Keep cables organized
  • Check charging progress
3. Car Charging Safety
  • Run engine periodically
  • Avoid overnight charging
  • Remove charger when done
  • Check connections regularly
  • Store equipment properly
Method 4: How to Charge Laptop with Phone Charger
While not ideal, you can charge a laptop with a phone charger in emergencies:
1. Compatibility Requirements
  • Must have USB-C with Power Delivery
  • Check minimum power requirements
  • Verify cable supports power delivery
  • Ensure proper connections
2. Phone Charger Method
  • Use only high-quality USB-C cables
  • Expect slower charging speeds
  • Monitor battery percentage
  • Watch for overheating
  • Be patient with charging time
Method 5: Universal Adapter Solution
A universal adapter can work when other methods aren’t available:
1. Setup Process
  • Verify voltage settings
  • Select correct connector tip
  • Test connection before full use
  • Monitor initial charging
2. Safe Operation
  • Connect to outlet first
  • Attach laptop connection second
  • Watch for unusual heat
  • Keep adapter unobstructed
In the next section, we’ll cover advanced troubleshooting for when your laptop’s not charging and how to maintain your battery’s health long-term.
Advanced Solutions When Your Laptop’s Not Charging
When alternative charging methods aren’t solving your power issues, or if your laptop won’t charge at all, you may need more advanced solutions. Let’s explore comprehensive troubleshooting steps and long-term solutions for persistent charging problems.
Software-Related Charging Problems
Many laptop battery not charging issues stem from software settings. Here’s how to identify and resolve these problems:
1. Power Settings Check
  • Open Windows Power Options
  • Review current power plan
  • Check charging thresholds
  • Reset power settings if needed
  • Update power policies
2. System Driver Updates
  • Open Device Manager
  • Locate “Batteries” section
  • Update Microsoft ACPI driver
  • Check for yellow warning icons
  • Restart after updates
3. BIOS Troubleshooting
When your HP laptop is not charging, the BIOS might need attention:
  • Backup important data
  • Download official BIOS updates
  • Follow update instructions carefully
  • Never interrupt BIOS updates
  • Verify charging after update
Hardware Issues When Battery’s Not Charging
If your laptop battery is not charging after software checks, examine these hardware components:
1. Battery Health Analysis
Generate a battery report: powercfg /batteryreport
Check for:
  • Current vs. design capacity
  • Recent charging patterns
  • Cycle count status
  • Unexpected changes
2. Physical Inspection
When your laptop won’t charge, check:
  • Port damage signs
  • Pin alignment
  • Connection stability
  • Overheating indicators
  • Battery swelling
Long-Term Solutions for Charging Issues
Prevent future problems when your laptop’s not charging with these maintenance tips:
1. Battery Care Best Practices
  • Keep charge between 20-80%
  • Avoid complete discharges
  • Use laptop regularly
  • Store properly
2. Charging Equipment Maintenance
  • Inspect cables monthly
  • Clean ports regularly
  • Store chargers properly
  • Replace damaged equipment
  • Keep spares available
Frequently Asked Questions
Why is my laptop not charging when plugged in?
Common reasons include:
  • Loose power connections
  • Software configuration issues
  • Damaged charging port
  • Battery health problems
  • Incorrect power adapter
How can I test if my laptop battery is bad?
Look for these signs:
  • Rapid power loss
  • Won’t hold charge
  • Physical deformation
  • Overheating
  • Age over 2-3 years
Can I use any charging method for my laptop?
No, always verify:
  • Voltage compatibility
  • Power delivery capabilities
  • Port specifications
  • Cable ratings
  • Safety certifications
When should I replace my laptop battery?
Consider replacement when:
  • Capacity falls below 50%
  • Charging is unreliable
  • Battery swells
  • Age exceeds 3 years
  • Performance degrades significantly
Planning for Future Charging Needs
As laptop charging technology evolves, consider these factors for future-proofing:
1. Modern Charging Standards
  • USB-C Power Delivery
  • Fast charging protocols
  • GaN charging technology
  • Universal standards
  • Cross-device compatibility
2. Backup Power Strategy
  • Multiple charging options
  • Portable solutions
  • Car charging capability
  • Emergency power banks
  • Universal adapters
3. Professional Support
Consider professional help when:
  • Physical damage occurs
  • Battery swells
  • Charging port fails
  • System board issues develop
  • Warranty coverage applies
Remember: Prevention through proper care and appropriate charging methods is always better than dealing with failures. Keep your charging equipment maintained, monitor battery health regularly, and address issues promptly to ensure reliable laptop power when you need it most.
About the Author
Zach Cabading is a contributing writer for HP® Tech Takes. Zach is a content creation specialist based in Southern California, and creates a variety of content for the tech industry
Disclosure: Our site may get a share of revenue from the sale of the products featured on this page.
